I'm looking to buy a new processor. I don't know the difference here its not quite clear. when i check the specs on both i see
* AMD Athlon 64 4000+ San Diego Integrated into Chip FSB Socket 939 Processor Model ADA4000BNBOX - Retail
(limit 10 per customer)
64 bit Support: Yes
Cooling Device: Heatsink and Fan
Hyper-Transport Support: Yes
L1 Cache: 64KB+64KB
L2 Cache: 1MB
Multimedia Instruction: MMX, SSE, SSE2, SSE3, 3DNOW! Professional
Operating Frequency: 2.4GHz
Process Type: 90 nm
Series: Athlon 64
Voltage: 1.35/1.4V
* Model #: ADA4000BNBOX
* Item #: N82E16819103529
* **This item is warranted through the product manufacturer only. what's this? In Stock
* Free FedEx Saver Shipping
* Combo Special
* Rating + 5Rating + 5Rating + 5Rating + 5Rating + 5[31 reviews]
* Move item to Wish ListMove To Wish List
AMD ADA3800DAA4BP Processors
View Pic
* AMD Athlon 64 3800+ Venice Integrated into Chip FSB Socket 939 Processor Model ADA3800DAA4BP - OEM
64 bit Support: Yes
Cooling Device: None - Processor Only
L1 Cache: 64KB+64KB
L2 Cache: 512KB
Process Type: 90 nm
Series: Athlon 64
Voltage: 1.35/1.4V
* Model #: ADA3800DAA4BP
* Item #: N82E16819103530
# AMD Athlon 64 3800+ Venice 1GHz FSB Socket 939 Processor Model ADA3800BPBOX - Retail
64 bit Support: Yes
L1 Cache: 64KB+64KB
L2 Cache: 512KB
Process Type: 90 nm
Series: Athlon 64
Voltage: 1.35/1.4V
# Model #: ADA3800BPBOX
# Item #: N82E16819103531
The only difference I see in the 3800 and the 4k is the level 2 cache is 1mb instead of 512 how important is that? I dont see any other difference although you may know of some which i would like to know about the operating freq is the same as i can see. Also what is the difference between the first 3800 and the 2nd? The only thing i see different is one says 1ghz fsb and other says intergrated into chip which im still not fully understanding. they are the same price which one is better?
64 bit Support: Yes
L1 Cache: 64KB+64KB
L2 Cache: 1MB
Process Type: 90 nm
Series: Athlon 64
Voltage: 1.35/1.4V
* Combo Special
View Pic
64 bit Support: Yes
L1 Cache: 64KB+64KB
L2 Cache: 512KB
Process Type: 90 nm
Series: Athlon 64
Voltage: 1.35/1.4V
64 bit Support: Yes
L1 Cache: 64KB+64KB
L2 Cache: 512KB
Process Type: 90 nm
Series: Athlon 64
Voltage: 1.35/1.4V
