Question Help me upgrade my system
rugupiruvu
71
Guys - I purchased a HP ProDesk 600 G2 SFF Intel Core i5 6th Gen Quad-Core 8GB 256GB SSD Windows 10 P on ebay 2 years ago and I think I am in need of an upgrade. I don't do anything crazy on my computer - simply use these apps but they are open ALL the time - MS Outlook, Excel (2-3 small spreadsheets) & Teams, Notepad++ Edge browser with 10-15 tabs and Evernote. The last two apps are the ones which I feel are slow to react vs my Lenovo 9th gen X1 with a much faster CPU & SSD
I've uninstalled a lot of things in case it was software causing random freezes for a couple of seconds in my Edge browser or slow to react Evernote which has some 15-page notes. Evernote is not the best designed software but it still works well on my laptop and their forums do have folks listing our a fast ssd as helping performance
With that being said, what do you folks think? Upgrade CPU & SSD or just SSD to start or just buy another PC? For my apps, is i5-6500 a slow CPU? Should I try overclocking? Data dump from Aida64 below. If there's some tool that helps me plot a graph showing which components are slowing down app performance, that'll help. Task manager supposedly has this on W10 but I run Server 2019
Thanks
Motherboard
CPU Type QuadCore Intel Core i5-6500, 3300 MHz (33 x 100)
Motherboard Name HP EliteDesk 800 G2 TWR
Motherboard Chipset Intel Sunrise Point Q170, Intel Skylake-S
System Memory 16263 MB (DDR4 SDRAM)
CPU Alias Skylake-S
CPU Stepping R0
Physical Memory
Total 16264 MB
Used 7905 MB
Free 8359 MB
Utilization 49 %
Drive #1 - SAMSUNG MZ7TY256HDHP-000H1 (238 GB) C:
Drive #2 - ST4000VN000-1H4168 (3726 GB)
Operating System Properties
OS Name Microsoft Windows Server 2019 Standard
Display
Video Adapter Intel(R) HD Graphics 530 (1 GB)
3D Accelerator Intel HD Graphics 530
Monitor Acer S231HL [23" LCD] (LWKAA0014340)
CPU Properties
CPU Alias Skylake-S
CPU Stepping R0
Engineering Sample No
CPUID CPU Name Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz
CPUID Revision 000506E3h
CPU VID 1.1451 V
CPU Speed
CPU Clock 3390.9 MHz (original: 3200 MHz, overclock: 5%)
CPU Multiplier 34x
CPU FSB 99.7 MHz (original: 100 MHz)
North Bridge Clock 3490.6 MHz
System Agent Clock 997.3 MHz
Memory Bus 1063.8 MHz
DRAM:FSB Ratio 32:3
CPU Cache
L1 Code Cache 32 KB per core
L1 Data Cache 32 KB per core
L2 Cache 256 KB per core (On-Die, ECC, Full-Speed)
L3 Cache 6 MB (On-Die, ECC, Full-Speed)
Motherboard Properties
Motherboard ID <DMI>
Chipset Properties
Memory Timings 15-15-15-36 (CL-RCD-RP-RAS)
Command Rate (CR) 2T
BIOS Properties
System BIOS Date 04/12/2019
Video BIOS Date Unknown
DMI BIOS Version N01 Ver. 02.38
Graphics Processor Properties
Video Adapter Intel Skylake-S GT2 - Integrated Graphics Controller [R0]
GPU Code Name Skylake-S GT2 (Integrated 8086 / 1912, Rev 06)
GPU Clock 350 MHz (original: 350 MHz)
Temperatures
CPU Package 30 °C
CPU IA Cores 29 °C
CPU GT Cores 30 °C
CPU #1 / Core #1 29 °C
CPU #1 / Core #2 27 °C
CPU #1 / Core #3 28 °C
CPU #1 / Core #4 26 °C
PCH Diode 39 °C
SAMSUNG MZ7TY256HDHP-000H1 34 °C
ST4000VN000-1H4168 31 °C
Lutfij
The PSU is a mere 200W unit with proprietary connectors to the motherboard, not to mention that the form factor is small. If you can get past the PSU limitations, you're relegated to working with low profile GPU's alone.
Might want to read through this;
https://h30434.www3.hp.com/t5/Desktop-Hardware-and-Upgrade-Questions/7th-gen-processor-upgrade-for-HP-ProDesk-600-G2-Desktop-Mini/td-p/8170897
I wouldn't spend anymore money on that prebuilt, outside of ram, though 16GB is plenty...so that's negated as well.
Yeah those little mini towers are what they are. Probably your best bet now is take out the ram and storage drives and move on. If on a tight budget I’d say try to get a decent b660 board and maybe an i3 12100 along with a budget case and power supply, then migrate the ram and storage over until you can do more with it.
rugupiruvu
71
I read that link. Do I need a GPU if I don't do any video editing? I only watch family videos which are shot on a Sony A6400 (XAVC S 4K 30P 100M) but when I'm not doing any other activity on the computer when watching these videos
Do you guys think the botleneck in my case is the CPU, RAM or the motherboard? I'm not necessarily tight on budget. I simply built it to be power-efficient since I pay very high power costs here in the north east (almost 40c/kwh). However, it's obviously getting my productivity down. I'm open to spending $1000 on a decent PC now. If I can get away buying something pre-built and I just have to add memory/storage, that'll be ideal since but I've also built a PC a while ago (took a full day LOL). With that being said, have you guys seen any forums where they post sample specs and even links to where to purchase (I think 2cpu had something in the past)
