Question Help me upgrade
minetom5841
Commendable
Sep 2, 2017
23
I have: https://support.hp.com/gb-en/document/c03533207
I would like to upgrade for as cheap as possible with used parts. I’m not looking for crazy performance just a little boost. I have a gtx 770 Twin Frozr laying around. I would like to upgrade my cpu and motherboard while re-using as many parts as possible to keep it cheap. Would this be possible, if so help me pick some parts please.
Nov 15, 2019
55
5
35
Putting an aftermarket mobo in a OEM case is a b****.
I wouldnt do it. The front panel headers, the audio and usb and psu connectors might be proprietary.
Maybe you can swap the cpu and boost the ram
