Hi, i have a problem with 123D. i'm using win 7 86bit, when i try to open the program my system brigs up a dialog box saying "123D has stopped working" what should i do?
Start with uninstalling and re-installing it. It may generate a log file somewhere that you can look at for more info, but with the limited info you have, I would recommend a reinstall or repair (if there is a repair option).
