Help me with a good Build?
Oct 7, 2018
20
I've got 1 part down but the rest I could use help with.
Currently I own an RTX 2080
So i was wondering what else would be a good build, I'm pretty much taking the RTX out of my current rig and building a brand new rig from the ground up, motherboard, CPU, everything
I don't want to make this a budget rig by any means but I don't want to also want to blow my entire bank
I know this kinda broad and some is down to personal taste in some regards but I'm not very good with parts in reguards with computers.
It is still a mighty rig, to me the only thing I will change is cpu and motherboard. I9-9900k and Z390 MB and that is it, no need for a whole new rig.
Current Rig is:
ASUS ROG Swift PG258Q 24.5" Full HD 1ms 240Hz DP HDMI Eye Care G-SYNC Esports Gaming Monitor with DP and HDMI Ports Qty: 1
ASUS PCE-AC55BT 802.11ac Wireless-AC1200 Bluetooth 4.0 PCIe / mPCIe adapter Qty: 1
CORSAIR Hydro Series H75 CW-9060015-WW Water / Liquid CPU Cooler 120 MM
ENERMAX Ostrog GT ECA3280A-BL Black / Blue Steel / Plastic ATX Mid Tower Computer Case Qty: 1
EVGA 220-G2-0750-XR 80 PLUS GOLD 750W ECO Mode Fully Modular NVIDIA SLI Ready and Crossfire Support Continuous Power Supply Qty: 1
G.SKILL Ripjaws V Series 32GB (2 x 16GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Intel Z170 Platform Desktop Memory Model ... Qty: 1
GIGABYTE GA-Z170X-UD3 (rev. 1.0) LGA 1151 Intel Z170 HDMI SATA 6Gb/s USB 3.1 ATX Intel Motherboard
Intel Core i7-6700K 8M Skylake Quad-Core 4.0 GHz LGA 1151 91W BX80662I76700K Desktop Processor Intel HD Graphics 530
LG Black 14X BD-R 2X BD-RE 16X DVD+R 5X DVD-RAM 12X BD-ROM 4MB Cache SATA BDXL Blu-ray Burner, Bare Drive, 3D Play Back (WH14NS40) ... - OEM
Microsoft Windows 10 Home - 64-bit - OEM Qty: 1
SAMSUNG SM951 256GB SSD 256G MZHPV256HDGL M.2 2280 PCIe PCI-Express 3.0 Internal Solid State Drive Bulk Package with USB3.0 ... - OEM Qty: 1
RTX 2080
Seagate Desktop HDD ST3000DM001 3TB 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive Bare Drive Qty: 2
it's primarily for gaming but i want to get into streaming and Video making. the res is 1920/1080 though i might upgrade in the furture, I forgot to say i'm keeping my current monitor, it's new. if by settings you mean the games settings, I want to go max
Budget wise I was thinking 2500$ to 3000$ and USA
Can keep your current RAM and PSU.
9900k would be worthwhile if you can find it in stock. I'll give you two options.
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor ($369.99 @ Amazon)
CPU Cooler: EVGA - CLC 280 113.5 CFM Liquid CPU Cooler ($105.72 @ Amazon)
Motherboard: ASRock - Z370 Extreme4 ATX LGA1151 Motherboard ($158.98 @ Newegg)
Storage: ADATA - XPG GAMMIX S11 480GB M.2-2280 Solid State Drive ($129.99 @ Amazon)
Case: Phanteks - Enthoo Pro M Tempered Glass (Black) ATX Mid Tower Case ($89.99 @ Amazon)
Total: $854.67
Generated by PCPartPicker 2018-10-24 11:59 EDT-0400
Or
CPU: Intel - Core i9-9900K 3.6GHz 8-Core Processor
Motherboard: ASRock - Z390 Taichi ATX LGA1151 Motherboard ($199.99 @ Newegg)
Total: $525.69
Generated by PCPartPicker 2018-10-24 12:01 EDT-0400
alright, for some reason or another a lot of stuff hasn't been working right (gamewise) on this one even after a factory reset, I was planning on building new and letting my little brother play my old one though as time goes on i'll probably change more. Is my current water cooler going to be ok for the I9-9900k?
Also, A new case, I do want a new case, what's a good one in that reguards?
Alright, that answers my question on the cooler and case
thanks mate
No everything is standard, I haven't changed anything in regards to overclocking, but for some reason Team fortress 2 and more prominently Counter strike go (a long with other game but those two are the oldest ones with some of the biggest issues) are crapping out on my current rig. I think i'll follow suit on the upgrade to CPU and MB, I'm primary gaming.
I factory reset my computer trying to fix A LOT of issues and most of them did get fixed but there are some like aforementioned that just won't stay stable.
This isn't why i wanted to make a new computer though it did help affect my decision.
While this is no longer on regards to my original question do you have any idea what might be the issue?
Before I had issues with almost every game, Rainbow six, Monster Hunter, GTA V. after installing my GPU I had insane frame rate (far past what all the benchmark test said) and stability but after the first day everything started messing up, getting stuck at unreasonable levels of Frame rate, stuttering, tried a lot to fix it, but not much worked, Factory resettled fixed Rainbow and monster hunter but I still have a lot of issues
Apologies that i'm going off tangent but rather then make another post in other forum maybe you'll have some sort of idea
Did you delete old gpu driver before dropping in the new GPU?
Yeah, I had a "SAPPHIRE NITRO+ Radeon RX 480 100406NT+8GOCL 8GB 256-Bit GDDR5 PCI Express 3.0 x16 HDCP Ready Video Card" before and I used DDU to uninstall it
Yeah my old one worked fine but I needed an upgrade, all drivers are up to date
I will definitely upgrade BIOS to get rid of the security hole first: https://www.gigabyte.com/Motherboard/GA-Z170X-UD3-rev-10#support-dl-bios
Pick F23f or F23g
F23g 5.43 MB 2018/03/09
Asia China America Europe
Update CPU Microcode
F23d 5.43 MB 2017/12/01
Update Intel ME for security vulnerabilities
F23b 5.45 MB 2017/06/30
Update CPU micro code to fix HT flaw issue
F22 5.46 MB 2017/03/14
V core Voltage adjust
tried to do f23g but it said it's not compatible with 64bit
