So I had this kit of ram since I built my PC 2 years ago running them nice and fine at XMP profile at 3000mhz and lately I found them again in stock at a decent price so I bought another kit to have 16gb...... the problem is that the XMP is no longer working.... is giving me OC failure.... at the start I believed that new kit is faulty so I took out the old kit from DIMM Slot 2 and 4 and put only the new one there and to my surprise it was working again with XMP at 3000mhz.... after that I took them out and put the old kit only on DIMM Slot 1 and 3 and I found out that maybe the slots are crazy -_- because It was not working with XPM again, it would give me OC fail again.... Funny is that if I would try the second XMP profile on 2666Mhz with ram only on DIMM Slot 1 and 3 It would work, but If I put both kits the XMP once again would fail on 2666Mhz....
This is the Motherboard that I have and the bios is the latest version. The CPU Is OC at 4.5 but I tried with default settings too ... no luck.
Is there any way to get all my ram working on 3000Mhz? I know that there is not a really big performance improvement, but I hate and it's killing me when I think that I can't use my ram at its full potential.....
P.S After some other research I found out that the problem might be the CPU.... I got an I7 6700K and the Max Memory Bandwidth is 34.1GB/s not sure if this is the problem or not.......
