Help me with build
SlaviXz
45
Hello.
I'm planning to buy a new pc and i don't know exactly which build is better.
You cant tell your advices, but i h@ve to say that my budget is 500 euro (+ - 50)
Cpu and gpu changes in all builds, but other parts i've already decided,
i already have the case and 3x 120mm fans with red light.
Hdd ill put from my old pc
Psu still is unknown but i think 500w will gonnaa be ok.
1st build:
Cpu a10-7850k (130 eur)
Gpu r7 260 1gb (100 eur)
Ram amd r9 gaming series 8gb 2400mhz(90 eur)
Mb asus a88xm-plus (60 eur)
Case Zalman mini tower zm-t2 (21 eur)
2nd build:
cpu Athlon II x4 860 (60 eur)
gpu r9 280 3gb (185 eur)
3rd build:
Cpu athhlon ii x4 860
gpu geforce gtx 960 2gb(190 eur)
4Th build:
A10 7850k or athlon ii x4 860
2X Asus Radeon hd 7750 directcu silent 1gb( 2x 80 eur)
CPU: Intel Core i3-4130 3.4GHz Dual-Core Processor (€109.84 @ Amazon Italia)
Motherboard: ASRock H97 PRO4 ATX LGA1150 Motherboard (€85.86 @ Amazon Italia)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory (€80.90 @ Amazon Italia)
Video Card: Zotac GeForce GTX 960 2GB Video Card (€219.14 @ Amazon Italia)
Power Supply: XFX ProSeries 450W 80+ Bronze Certified ATX Power Supply (€49.89 @ Amazon Italia)
Total: €545.63
Generated by PCPartPicker 2015-02-09 08:19 CET+0100
CPU: AMD FX-6300 Six Core Edition
Motherboard: Asus M5A78L-M USB3.0
RAM: Kingston HyperX 1600Mhz (2X4GB)
Video Card: R9 270X AMD/ATI Saphire
PSU: Seasonic Sii21 80+ Bronze certified 500w PSU
All of this comes completly in your budget and is still better than all of the builds
Total: €545.63
No need to spend your hard earned money on FX 9590 , its just a overclocked version of 8350 :)
Evan a FX 4300 will beat IC i3
i suggested the cheapest motherboard that i can , any cheaper motherboard will destroy your perfomance as cheaper motherboards dont have capacity to power all of 8 cores of AMD FX 8350
A10 Series os for ppl who are not going to use any gpu specially for ppl who are doing editing and stuff, A10 7850k is an APU i.e its has a integrated gpu which is no good for gaming and ofc futureproofing
Nowadays games are being really CPU INTENSIVE and AMD 8350 can handle them
For the MOBO i must have took a MSI's one they have 2X SLI ie you cand add to GPU anytime you need
AMD FX 8350 is ofc powerful than i3 and also crosses i5 but the only place it lags is it has a weak single core perfomance but it has a better price/perfomance ratio
So better stick to 8350 and you will be futureproof to 3-4 years until AMD launches a new architecture
u cant have both good cpu as well as gpu at that budget .. if u get fx 8350 u will have sacrifice on gpu .. and fx 8350 dissipates lots of heat , so any mobo wont do the job + u will have too look for cpu cooler and a good mobo to overclock it which in-turn leads to increase in ur budget for the build or reduce the price allotted for ur gpu .
and about i3 vs fx 4300/6300 unless u overclock , performance per core i3 beats it ... whatz the use of lots of core which cant perform fast . why buy 100 bicycles when u can get a bike at same price
