Help me with computer
Jan 3, 2019
Hello, so I had a really old computer and wanted to upgrade it. So I did. I bought a motherboard (z270 tomahawk) a cpu (i3 8100) and ram (8gb ddr4) and if I turned pc on the fans and LED are on but monitor is off and RGB mouse doesnt have the light. So I was wondering if you could help me.
The 8100 does not work with that z270 motherboard. The z270 motherboard will only work with a 6th or 7th gen Intel CPU. You will either need to get a new CPU, or get a b310/b360/z370/z390 mobo.
For the 8100 I would go with this motherboard.
PCPartPicker part list: https://pcpartpicker.com/list/KcYGGG
Price breakdown by merchant: https://pcpartpicker.com/list/KcYGGG/by_merchant/
Motherboard: Gigabyte - B360M DS3H Micro ATX LGA1151 Motherboard ($69.99 @ Amazon)
Total: $69.99
Generated by PCPartPicker 2019-01-03 08:51 EST-0500
Total: $69.99
Sorry , they are the same socket , but NOT compatible:
For the 8100 , here's a nice one:
Motherboard: ASRock - B360 Pro4 ATX LGA1151 Motherboard ($95.78 @ SuperBiiz)
Total: $95.78
Generated by PCPartPicker 2019-01-03 09:10 EST-0500
