Help me with "Intel E5400" PC build
GaneshEtech
Commendable
Jan 15, 2017
4
I have a few Components with me, please suggest me a motherboard & PSU Compatible to the following parts I have
*1 GB NVIDIA GT630 DDR3 (owned)
*Intel Pentium Dual-Core E5400 @2.7Ghz (owned)
*4GB RAM DDR3 1066 MHz (owned)
*160 GB HDD @5,200 RPM (owned)
please suggest me a a favourable motherboard and PSU to build a new PC
sorry to say there are a number of motherboards used with the E5400 namely;
ASRock G41C-GS R2.0 LGA775/ Intel G41/ DDR3&DDR2
Intel DG41WV Micro ATX Motherboard Socket LGA775 2 Slots DDR3
ASRock G43Twins-FullHD LGA 775/Socket T DDR3 1066
ASRock G41C-GS R2.0 LGA775 Intel G41 DDR3
Biostar G41D3+ Intel G41 LGA 775 DDR3 MicroATX
Intel DG43RK (BOXDG43RK) Motherboard, LGA775, DDR3, Intel G43, Micro ATX
to name a few, and it will be yours to search the web if it supports this CPU of yours, I am sorry but I cannot scour user manuals for you
I already made a suggestion for power supply in earlier message
Im looking out for a DDR3 motherboard, the one which you mentioned is DDR2
Yes, used one will do, just mention which motherboard and PSU will be suitable for this
