K kaelwaters33 Prominent Sep 11, 2017 2 0 510 Sep 11, 2017 #1 can you remove the APU'S video card and then install the dedicated one that you bought?
K Kasper Jorgensen Estimable Jun 10, 2017 3,080 1 3,960 Sep 11, 2017 #2 Full system specs? Upvote -1 Downvote
rgd1101 Don't Moderator Nov 7, 2011 74,324 4,091 176,290 Sep 11, 2017 #3 You don't need to removed it for dGPU. Upvote 0 Downvote
K kaelwaters33 Prominent Sep 11, 2017 2 0 510 Sep 12, 2017 #4 i said CAN you remove the apu's videocard and replace it w dedicated. P.S i dont have an sli motherboard Upvote 0 Downvote
K Kasper Jorgensen Estimable Jun 10, 2017 3,080 1 3,960 Sep 12, 2017 Solution #5 Just disable it in BIOS and yes you can use a dGPU Upvote 0 Downvote Solution
