Hi!
Tried posting this earlyer but i cant find it in the forums now so i'll try again...
This will be my first DIY build, can you please check if the parts are ok?
Approximate Purchase Date: this week
Budget Range: 650-700$ total
System Usage: Gaming
Parts:
- ASROCK B85M-HDS
not really sure about the motherboard, any tips?
- Intel Core i5 4570 s1150
- FSP RAIDER S ATX 550W 80+ Silver
OR
- FSP Hexa 500W
is it worth to go with the more expansive RAIDER or can i just stick with the cheaper HEXA? (about 14$ difference here) Or would you recommend something else? Maybe less W would be enough?
- Kingston 8GB 1600Mhz DDR3 HyperX Blu CL9 XMP KIT 2x4GB (KHX1600C9D3B1K2/8GX)
I'm also thinking about buying BEAST instead of BLU, maybe even a 1833Mhz BEAST, (that would be CL9 also, the cost difference is around 14$) but i read that the upgrade isnt worth the extra money since you cant really notice any difference. Also the 1833Mhz might be a problem for the motherboard?
- Cooler Master N300 NSE-300-KKN1 case
- 1TB WD 3.5" Caviar Blue SATAIII 64MB cache winchester (WD10EZEX)
- 120GB Samsung MZ-7TE120BW SSD 840 Series Evo Basic (MZ-7TE120BW)
- LG GH24NSB0 5,25" DVD SATA OEM
Not planning to buy a GPU yet, gonna use the comp with the intel integrated graphix for a few months. When i do buy one i'm planning around 200$, any suggestions?
Do you need to buy OS: No
Parts Preferences: Intel CPU, the rest doesnt really matter.
Overclocking: Probably not but i'm open to suggestions.
SLI or Crossfire: Probably not but i'm open to suggestions.
Your Monitor Resolution: 1680x1050 Not buying a new monitor yet, maybe in a few months or so, i'm hoping this rig will be able to run on higher resolutions, not planning multiple monitors or anything super-fancy.
Reason for upgrade: have a gaming laptop but its old, and i'd like a good desktop comp, preferrably one that i wont have to upgrade for the next 4-5 years, but i'm really on a budget...
Thanks for all the help!
(had some problems with posting, if i manage to post this twice, sorry)
Oh, as some additional information, tho its not too important, i'd prefer going with more power-friendly solutions if you have suggestions. Thanks again
Parts:
- ASROCK B85M-HDS
OR
- FSP Hexa 500W
