help me with my build
saintequila
431
5
18,795
Going to build a mid range unit and wonder if these components will do just fine in latest titles
(not going to oc, sli/cf or online just pure casual campaign gaming) kindly correct and suggest thanks
CPU: FX 6300 @3.5ghz
MOBO: Gigabyte 970A-DS3P
GPU: Zotac GTX 770 2gb
RAM: Kingston Fury 2x4gb@1866
PSU: Seasonic ECO 600BT
HDD: WDC Blue 1tb@7200RPM
CASING: Cooler Master N300
yeah either that or an r9 280x
i live in the Philippines, theres no pc part picker here. Newer? Can a gtx 960 suffice? I wont need that much hdd capacity
i would recommend getting a power supply that is at least tier 3, preferably tier 2 here - http://www.tomshardware.co.uk/forum/id-2547993/psu-tier-list.html
yes a 600w would easily power that build, just make sure the psu is reliable or it could potentially fry your parts
also consider getting an aftermarket cpu cooler in the future. check your temps when it is built.
ok i think ill be getting the Seasonic SII12 600w
