APPROXIMATE PURCHASE DATE: Next week or so.
Budget: <$800
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: gaming, movies, internet, home work
PARTS NOT REQUIRED: Keyboard, Mouse
PREFERRED WEBSITE(S) FOR PARTS: Newegg, cheapest
PARTS PREFERENCES: Too new to be picky about this stuff
OVERCLOCKING: Maybe
SLI OR CROSSFIRE: Prob not
MONITOR RESOLUTION: all of the above
ADDITIONAL COMMENTS:
This is my first build. I am very new with everything. Ive done research to figure out stuff on my own but can only go so far. THANKs FOR YOUR HELP.
Also, Im just trying to build this comp up for gaming and movies.
Heres what ive picked out so far:
BFG Tech LS SERIES LS-550 550W Continuous @ 40°C ATX12V 2.3 / EPS12V 2.8 SLI Certified CrossFire Ready 80 PLUS Certified ... - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817702008
PNY VCG981024GXEB GeForce 9800 GT 1GB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814133243
Western Digital Caviar SE WD3200AAJS 320GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM
Item #: N82E16822136098
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136098
LG 22X DVD±R DVD Burner Black SATA Model GH22NS30 - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136152
Now, for the next 3 (cpu, motherboard, and ram) I need help deciding between two differant set ups which would be faster/better overall.
The first set up: Set up "A"
ASUS M4A78T-E AM3 DDR3 AMD 790GX ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131366R
AMD Phenom II X4 945 Deneb 3.0GHz Socket AM3 125W Quad-Core Processor Model HDX945FBGIBOX - Retail
Item #: N82E16819103675
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103675
OCZ Reaper HPC 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Dual Channel Kit Desktop Memory Model OCZ3RPR13334GK - Retail
Item #: N82E16820227293
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227293
The total for everything above comes out to about: $690 with shipping
Set up "B"
AMD Phenom II X4 940 Deneb 3.0GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM2+ 125W Quad-Core Black Edition Processor - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103471
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
GIGABYTE GA-MA790X-UD4P AM3/AM2+/AM2 AMD 790X ATX AMD Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128387
So, which two would be better? Also, i need a monitor for around $100. Maybe a widescreen 19 inch monitor. Any suggestions?
Also, for OS I plan on downloading Windows 7.
And please let me know if any parts are not compatiblie or wont run correctly so i might change those.
Thanks for all help!!!
Budget: <$800
OVERCLOCKING: Maybe
Set up "B"
