I need some help for a build:
Things I'm going to do/want to do:
Play games like COD/BF3 flawlessly with high FPS on high graphics.
Stream Games with no performance impact on games (When I stream with my PC currently, it lowers my FPS in game)
Budget:
Around $1000 range.
Looking to buy in the next 1-2 months.
Case: I'm currently using the HAF 912. I feel like this is sufficient and is in my price range.
CPU: I was thinking of getting an i7, but I'm not sure which tier.
I know people said you only need 4 cores for gaming, but I would like the extra processor speed when I'm not gaming also.
Cooling: Maybe just a CPU cooler or one of those fans with the radiator attached to it.
Storage: 128GB SSD (This is enough for me)
Graphics: I Need some advice here. I have heard that SLI of two cards are usually better and cheaper than a single higher tier/expensive card.
MOBO: What MOBO is a good pick for me? I want to get a cheap one, but at the same time I don't want to skip out on a crucial part if this is important and have it bring down my performance.
Network Card: Is this a must when gaming?
PSU: Will decide after I pick which video card to get. I will get a modular PSU though.
Ram: 8GB is good enough for me. (question: if I stream would I need more than 8GB?)
Budget:
Around $1000 range.
