Help me with my i5 7600 build
DarthGeo
Commendable
Apr 20, 2016
5
Intel i5 7600
Asus H110M-D
Kingston KVR 8GB DDR4 2133
Aerocool Rave 80Plus 600Watts
Is this build correct?
This build is intended for Android Development
And can you please recommend a budget video card for photoshop/android studio
I already have peripherals, HDD, case, monitors
You would need to install a 6th Generation Skylake Processor to flash the BIOS before a 7th Gen i5 7600 would work. A Celeron G3900 is about $45. The alternative is to buy a B250 Chipset motherboard that needs no BIOS update and uses DDR4-2400MHz memory.
Video card should have at least 2GB memory. NVidia Geforce GTX 1050, for example.
I could probably ask the retailer while i'm there to update the bios so it can support kaby lake, if ever...
I assume everything is in order, how about the VC??
So here is my final build:
INTEL CORE i5 7600 (3.5GHZ, 6MB CACHE LGA1151)
MSI B250M PROVDH
KINGSTON HYPER X FURY BLACK 8GB 2400 DDR4
ASUS GT730 2GB DDR3 128BIT
Generic 600W PSU
What do you think guys?
