help me with my internet connectivity problem?
nhoj333
9
A computer running windows xp 32 bit at my work for some reason all of a sudden cant connect to the internet neither through lan or WIFI.
it has a 100mpbs connection and says its connected but when i click the browser it says proxy at the bottom left hand corner .
ive tried everything from auto repair to pinging the dns server and looking at ipconfig etc
heres a ipconfig screen shot if it helps
and also this happened shortly after a network multi scanner printer was installed but i dont believe any network settings were changed , the internet through lan is through a sonic wall router and a belkin router.
any ideas? :/
nhoj333
9
i checked the boxes in the internet properties to get its information automatically, if thats not what you are talking about how do you recommend i set it up to get it to get it from DHCP automatically?
nhoj333
9
im pretty sure i set dhcp upto 100 , i tried changing the ip to like .50 too and nothing, but ill check the settings today .
weird little problem
Similar threads
