[SOLVED] Help me with my PC build!!
Jan 20, 2019
I have a budget of $1200 and was looking for a good Pc build....Can anyone suggest me some good parts for my pc(including monitor)...Plz ignore the looks...Is there any possibility of including GTX 1070?
U may ignore coolers too..Hoping to get a nice reply...Thank You
Here is the part list you can consider for buying
CPU AMD - Ryzen 5 2600X 3.6 GHz 6-Core Processor (You can also consider Intel I5 if your sole purpose is gaming)
CPU cooler Cooler Master - MasterLiquid ML240L RGB 66.7 CFM Liquid CPU Cooler
MotherbOard - Gigabyte - X470 AORUS ULTRA GAMING ATX AM4 Motherboard
RAM eam - Vulcan 16 GB (2 x 8 GB) DDR4-3000 Memory (You can buy RAM from anyother manufacturer, the only thing you have to
consider is RAM speed)
Video Card MSI - GeForce RTX 2070 8 GB VENTUS Video Card
PSU EVGA - 750 W 80+ Gold Certified Semi-Modular ATX Power Supply
You can choose Storage and Case as per your requirement. Also for better performance I strongly recommend you to get a SSD
