Help me with soldering "AC power wires" directly on the MB. (Removing the faulty power jack I damaged all 3 board connectors.)
kraft_mkd
22
Hello everyone.
This is the motherboard from an old ASUS EEE PC netbook.
The Power jack failed and it was removed in a very wrong way, damaging all (3) board connection in a non-reparable way.
Can someone please identify (if possible at all) and mark two alternative places where can I solder two wires directly on the motherboard and use them to power the laptop?
Thanks!
K
Opsite side:
Opsite side:
Thanks!
K
Thank you scout! I realy appreciate your help.
That power jack was already replaced three maybe four times. (It would become very loose just after one year.)
I don’t think there was over-voltage. Wrong polarity by mistake, posiible.
Asus 1005HA p/n08g2005ha13f
Scout.
If you check my pictures you can see that I already marked the polarity on my pictures. That`s not an issue or problem.
I need someone who can read the board markings, to pin-point exactly, where should I solder the wires because board-contacts are totally ripped-off and damaged . I need alternative place.
K
