hello everyone.....
i have a second question here........
i am planning to build a custom pc at home
i am basically building it for photoshop,after effects,autocad maya and others,nuke,sony vegas,adobe illustrator,and similar softwares..
i have 2 choices of cpu ==
1-i7 4790k
2-i7 5820k
the gpu i will be choosing is gtx 970
i will keep the ram at least 16gb
i dont wanna play games,will only play 1 or 2 for refreshment...
and also i dont want to overclock the cpu presently foe at least year or two.........
if i choose the i7 5820k the with it can i put a corsair h80i cooler?//
also iam on a budget of aprox 150000inr ie 2340.99usd
and if the x99 budget goes to 140000ind it will much better as i want to save each each and every penny/rupee.....
also i dont want to spend too much on case....
i want to build and this build should last at least 5 years and max 10
thank you and pls help.....will also buy a genuine windows os....
1-i7 4790k
2-i7 5820k
