Help me with this build
For anything below 4k resolutions, your good to go. No complaints.
The only minor con would be that purple drive. Are you using it for live security webcam stuff? If not, a blue or black drive will be better.
Didn't know that purple is special i will switch it.
i have dual monitor setup: 23.8 inch 1440p 165hz with gsync
For a dual monitor setup, you should get at least a 1080. 1070 is not the best with a single 1440p monitor. So if it is TWO 1440p monitors with a 165hz refresh rate the 1070 would really be bad especially if you really want to full advantage of 165Hz refresh rate.
i dont think its matter beacuse i play my game just on 1 screen
Whats the differnt between black and blue?
