Help Me... :)
lixy
6
Can I Use Upgrade My Prosessor
AMD Athlon 64 X2 6000 Socket AM2 Gaming Processor
Can I Use It With MY MotherBoard
Intel(R) Core(TM)2 Duo CPU E4500 @ 2.20GHz
2 x Pentium II
6
15
13
BFEBFBFF000006FD
Intel Corporation
GenuineIntel
x64 Family 6 Model 15 Stepping 13
06FD
800 MHz
12
2194 MHz
XU1 PROCESSOR
64
3853
2048
NULL MHz
OK
If you want to upgrade your CPU, you'll have to figure out the exact model of your motherboard, and what socket you have. Then you'll have an easier time determining what processing units you're compatible with. But don't expect an AMD to fit in an Intel socket(or vice versa), because that's highly unlikely to ever happen.
