Help Me :)
John Troy
Which should i choose?
intel core i5 7500
asrock b250m pro
2x4gb corsair vengeance lpx 2400mhz
seasonic m12ii 520w evo
or
intel pentium g4560
palit gtx 1060 6gb
asrock b250m pro
The G4560 list is better, but give me a budget and i'll make you a list.
Get one of these if you're in the US.
CPU: Intel - Pentium G4560 3.5GHz Dual-Core Processor ($58.88 @ OutletPC)
Motherboard: Gigabyte - GA-B250M-Gaming 3 Micro ATX LGA1151 Motherboard ($69.98 @ Newegg)
Memory: G.Skill - Ripjaws 4 series 8GB (2 x 4GB) DDR4-2400 Memory ($59.92 @ Amazon)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive ($46.88 @ OutletPC)
Video Card: EVGA - GeForce GTX 1060 3GB 3GB GAMING Video Card ($159.99 @ Newegg)
Case: Corsair - 100R ATX Mid Tower Case ($39.99 @...
So it's between an i5 and no GPU or a G4560 and a strong GPU?
Ultimately, it depends on your needs.
That being said, there's very few situations where the i5 alone will outperform a G4560 with a discreet GPU. The G4560 is fairly strong for what it is, and if you're gaming - paired with a 1060 (or even a 1050TI) would be the hands-down winner.
well i'm not a heavy gamer but im thinking of getting the i5 and get a gpu in the future
If gaming isn't a primary task for your system, it would be better to get the i5 and, as you say, add a GPU later on down the road. The power supply listed would run a 1060/1070 no problem.
Case: Corsair - 100R ATX Mid Tower Case ($39.99 @ Newegg)
Power Supply: Corsair - CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply ($29.99 @ Newegg)
Total: $465.63
Generated by PCPartPicker 2017-05-11 10:56 EDT-0400
Video Card: Gigabyte - Radeon RX 580 4GB Gaming 4G Video Card ($198.99 @ SuperBiiz)
Total: $504.63
CPU: AMD - Ryzen 5 1400 3.2GHz Quad-Core Processor ($163.88 @ OutletPC)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard ($77.98 @ Newegg)
Total: $578.63
Generated by PCPartPicker 2017-05-11 10:57 EDT-0400
