Help me
Press the "del" key just before the post screen to enter the bios. In the bios, look for the boot order setting. Change to cd>hardrive, save and exit. If this doesn't work, check your power supply and sata cable connections to the hardrive. If this doesn't work, change your sata mode to "native ide" save and exit.
