HELP ME
mr mage 4565
24
THIS IS REALLY LONG SO PLZ READ IT ALL
Okay so i am just starting to build my FIRST computer ever and i need some help i have everything all ready but just wanted to check first here is my build.
PSU= Rosewill RG630-2 630W ATX12V v2.3, SLI Ready, Active-PFC Power Supply, UL,FCC,CE,CB,ROHS - Retail
CASE= Rosewill R5604-TBK 0.8mm Japanese Cold Rolled Steel Screw-less Dual 120mm Fans ATX Mid Tower Computer
Cooler= ZALMAN CNPS9500 AT 2 Ball CPU Cooling Fan/Heatsink - Retail
Possessor= Intel Core 2 Duo E8400 Wolfdale 3.0GHz LGA 775 65W Dual-Core Processor Model BX80570E8400 - Retail
Mother Board= GIGABYTE GA-G41M-ES2L LGA 775 Intel G41 Micro ATX Intel Motherboard - Retail
Ram= G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-4GBNT - Retail
GPU= EVGA 896-P3-1265-RX GeForce GTX 260 Core 216 896MB 448-bit GDDR3 PCI Express 2.0 x16 HDCP Ready Video Card
Hard Drive= Western Digital Caviar SE WD3200AAJS 320GB 7200 RPM SATA 3.0Gb/s 3.5" Hard Drive - OEM
DVD Burner= LG 22X DVD±R DVD Burner Black SATA Model GH22NS30 - OEM
Grand Total of around $710 it is my gaming rig that i am going to build now what i need you to do is tell me if it is a good rig.
Also i would like u to give me the best gaming possessor for under $190 it can be either intel or AMD and the best video card under $200 please help me.
Thanks in advance.
PSU is trash the motherboard is not great either. Only get psu that are branded corsair, ocz, Ultra, thermaltake and antec; to be safe.
The best cpu under $200 is the x4 940 with a 790gx motherboard. In my opinion the best single card under $200 is the gtx 260 and the best dual card is two 4770's in crossfire. Everything else looks good.
i don't think the PSU is trash because from the reviews people say it is great also if i were goign to crossfire i would need somebody on here to post links on where to get a motherboard that supports crossfire and any other componets nessasary
give me a solid reason why rosewill PSU are bad if u can do that then give me a link to a PSU that you would pick that had 600W
Rosewill PSUs are notorious for frying, and taking half of your rig with it. A PSU is something you NEVER want to skimp on. You came here for help, we know what we're talking about, take the advice.
Get a Corsair or PC Power & Cooling PSU. Two of the best brands out there.
Yes I think everything else looks good!
However I would go with the x3 720 or x4 940 with a 790gx motherboard, for better performance. But the e8400 is a great overclocker but still not as fast as the multi core x3 and x4 phenom II cpu's.
x3 720 -http://www.newegg.com/Product/Product.aspx?Item=N82E16819103649&Tpk=x3%20720 $139
x4 940 - http://www.newegg.com/Product/Product.aspx?Item=N82E16819103471 $189
TA790GX -http://www.newegg.com/Product/Product.aspx?Item=N82E16813138130 $109 with crossfire 8x lane support!
EDIT: The Darknight as Fortunex said is better.
You can, but the extra money won't be worth it. The E8500 and E8600 have higher multipliers, so you don't need to up the FSB as much when OCing, but whether you want to get those or not is your choice.
Alternatively, the Phenom 720 performs the same as the E8400 in games and better in multi-tasking and stuff when they are OC'd the same, but the E8400 can overclock farther.
Yes, that motherboard will work with dual 4770s.
would this motherboard work with crossfire x i will be using 2 Radeon 4770
BIOSTAR TFORCE TA790GX 128M AM2+/AM2 AMD 790GX HDMI ATX AMD Motherboard - Retail
140W Phenom and loaded for OC
Model
Brand BIOSTAR
Model TFORCE TA790GX 128M
Supported CPU
CPU Socket Type AM2+/AM2
CPU Type Phenom / Athlon 64 X2 / Athlon 64 / Sempron
FSB 2600MHz Hyper Transport (5200 MT/s)
Chipsets
North Bridge AMD 790GX
South Bridge AMD SB750
Memory
Number of Memory Slots 4×240pin
Memory Standard DDR2 800/1066(1066 by AM2+ CPU)
Maximum Memory Supported 16GB
Channel Supported Dual Channel
Expansion Slots
PCI Express 2.0 x16 2 x PCI-E x16 2.0 Slot (CFX x8)
PCI Express x1 2
PCI Slots 2
Storage Devices
PATA 1 x ATA100 2 Dev. Max
SATA 3Gb/s 6
SATA RAID 0/1/5/10
Onboard Video
Onboard Video Chipset ATI Radeon HD 3300
Onboard Audio
Audio Chipset Realtek ALC888
Audio Channels 8 Channels
Onboard LAN
LAN Chipset Realtek 8111C
Max LAN Speed 10/100/1000Mbps
Rear Panel Ports
PS/2 2
Video Ports D-Sub + DVI
HDMI 1 x HDMI
USB 4 x USB 2.0
Audio Ports 6 Ports
Onboard USB
Onboard USB 3 x USB 2.0 Header
Physical Spec
Form Factor ATX
Power Pin 24 Pin
Packaging
Package Contents TFORCE TA790GX 128M
Driver Disk
User Manual
Rear I/O Panel Shield
IDE/PATA Cable
SATA Cable
4-pin to SATA Power Cable
would this motherboard work?
the extra PCI 2.0 x 16 would it be just as good or a little badder? also i was wondering what would be the best crossfire configuration for $200 or less?
would this power supply be a good choice too?
BFG Tech LS SERIES LS-550 550W Continuous @ 40°C ATX12V 2.3 / EPS12V 2.8 SLI Certified CrossFire Ready 80 PLUS Certified Active PFC Power Supply - Retail
Winner of Anandtech's Gold Editor's Choice Award sup
