[Help] Memory Speed
Jan 2, 2019
6
Hi guys, hope you are well. I just put up together this build to play fornite and stream through twitch:
CPU: Ryzen 5 2600x 4.2ghz
GPU: Gigabyte Geforce 1070
PSU: Corsair RM 650x
RAM: x2 8gb Corsair Vengeance 3200mhz
MOBO: Asus Prime B-450 plus
Anyway, I was just checking the speed of my stuff, and I got this numbers checking the RAM:
https://pasteboard.co/HVVchZD.png
https://pasteboard.co/HVVcFIZ.png
Should I change anything in BIOS to get the best performance of my memories?
Thanks in advance,
Ramidec.
Jan 2, 2019
6
Thank you for your help!!
How do I set XMP in BIOS? Is there any risk? And also, will changing the RAM frecuency affect in any way the performance for good?
Thanks,
XMP is setting in the memory itself, it's internal controller, BIOS has to read it end recognize it's presets. In Asus MBs setting is called DOCP and that's what you turn on. If ram has 2 or more XMP presets, DOCP will show them. If 2 or more you can choose in DOCP which one to activate. The setting will stay in BIOS until you reset CMOS and than would drop to starting frequency. If anything goes wrong, just reset CMOS.
Ryzen responds nicely to RAM speed and gives better performance.
It's not only frequency that's written in the XMP but also timings and voltages.
Similar threads
