Hi All,
I am mid build and have just run into an unforeseen problem.
I am using this case: https://www.thermaltake.com/Chassis/Mid_Tower_/Versa/C_00003288/Versa_J24Tempered_Glass_RGB_Edition/Design.htm
with this cooling:
http://www.coolermaster.com/cooling/cpu-liquid-cooler/masterliquid-ml240r-rgb/
I had hoped to mount the radiator and fans at the top of the case, but sadly it is 2mm too wide and blocks the ram slots.
So what I have done is remove the upper two case fans from the front and replaced them with the two ML240 cpu fans, and then mounted the radiator behind them. The two ML240 fans are pulling air from outside the case and pushing the air across the radiator into the case.
This leaves me with the two case fans which I can mount at the top. The question is should those two top fans be pulling air into the case or extracting it?! I would guess extracting, otherwise I would have 5 intake fans and one exhaust fan.
But I am worried whether GPU will get enough cool air if they are extracting as the intake air is now passing over the radiator as it enters the case? I don't know how much the air passing across the radiator heats up.
I assume this setup is actually better for CPU cooling as the fans are pulling cooler air from the room across the radiator, rather than warmer air from inside the case (if mounted at the top), but I'm concerned about the GPU. What would be normal way to set this up? I assume having one of the top fans as intake and one as exhaust is counter-productive?
with this cooling:
