I have a i7 9700k cpu
Rtx 2080ti
16gb ram
Monitor 1440p 144hz.
Minecraft fps at 140+
they can be above 200 fps easy
then drop to 0 fps for a second or two and build back up frames then drop again. sometimes every 10 seconds other times every 20 seconds at times every 5 seconds. Same issues if i have 12+ chunks, 6 or even 2 chunks. All settings set to fast.
1080p or 1440p both do the same thing. Both cpu and gpu load under 50% well depending on the settings. Temps also average. Around 120f or 50c
I tried a different gpu. My old gtx 1070 same issue i dont have any shaders
Rtx 2080ti
16gb ram
