V Vojin Honorable Dec 26, 2013 292 0 10,860 Mar 10, 2014 #1 When i run it there are like coulour glitches,i reinstalled drivers i tried even 14.1 and 13.11 and it doenst work
D Dalle4 Honorable Jul 12, 2013 34 0 10,540 Mar 10, 2014 #2 Just to be sure, have you tried reinstall minecraft? also is this something which has just happend or did minecraft work in the past? Upvote 0 Downvote
D Dragoic Honorable May 5, 2013 164 0 10,710 Mar 10, 2014 #3 If you need to clear out a driver and eveything that comes with it. Then here is a tool: Display Driver Uninstaller. Free and it works like a charm. http://www.wagnardmobile.com/DDU/ Upvote 0 Downvote
V Vojin Honorable Dec 26, 2013 292 0 10,860 Mar 10, 2014 #4 i reinstalled minecraft 4 times and drivers also Upvote 0 Downvote
Xainoda Reputable Mar 10, 2014 18 0 4,520 Mar 10, 2014 #5 Can you post a screenshot of it? Upvote 0 Downvote
V Vojin Honorable Dec 26, 2013 292 0 10,860 Mar 10, 2014 #6 https://drive.google.com/file/d/0B5x3diVA5Gy2SUZLeWdUQm9mdUE/edit?usp=sharing Upvote 0 Downvote
V Vojin Honorable Dec 26, 2013 292 0 10,860 Mar 10, 2014 #7 https://drive.google.com/file/d/0B5x3diVA5Gy2cjBMV2xXNDltVWs/edit?usp=sharing Upvote 0 Downvote
Xainoda Reputable Mar 10, 2014 18 0 4,520 Mar 10, 2014 #8 Vojin : https://drive.google.com/file/d/0B5x3diVA5Gy2cjBMV2xXNDltVWs/edit?usp=sharing Try to set Catalyst A.I. to standard. Upvote 0 Downvote
D Dragoic Honorable May 5, 2013 164 0 10,710 Mar 10, 2014 #9 What Java version are you using? Upvote 0 Downvote
D Dragoic Honorable May 5, 2013 164 0 10,710 Mar 10, 2014 #11 As Dalle4 said: is this something which has just happend (after driver update) or did minecraft work in the past? (Other gpu/driver) When you uninstall Minecraft. Is it by deleting the entire C:\Users\%user%\AppData\Roaming\.minecraft folder? (Rememeber to move the "saves" folder) Upvote 0 Downvote
V Vojin Honorable Dec 26, 2013 292 0 10,860 Mar 10, 2014 #12 i delete everything (with entire .minecraft...) Upvote 0 Downvote
V Vojin Honorable Dec 26, 2013 292 0 10,860 Mar 10, 2014 #13 and i setted all to application setting in cataclyst Upvote 0 Downvote
D Dragoic Honorable May 5, 2013 164 0 10,710 Mar 11, 2014 #14 The only thing i can find say it is a AMD driver issue. http://www.reddit.com/r/Minecraft/comments/1wxulc/invisible_blocks_bug/ Upvote 0 Downvote
D Dragoic Honorable May 5, 2013 164 0 10,710 Mar 11, 2014 #16 So. I just got my hands on a R9 280X. Which should bring up same issue. Installede minecraft. Without texture mods or anything. Complete normal installation with all settings at max. Screenshot: https://dl.dropboxusercontent.com/u/6836191/Minecraft.png Spec used for testing. CPU: I7 3770 GPU: XFX R9 280x Motherboard: Asus Maximus V formula PSU: Dark Power Pro 10 650W RAM: Corsair Vengeance Low profile 16GB HDD/SSD: 2x Kingston HyperX 250GB in raid0 Sound Card: Creative Sound Blaser ZX Upvote 0 Downvote
V Vojin Honorable Dec 26, 2013 292 0 10,860 Mar 11, 2014 #17 i dont have any mods or texuters Upvote 0 Downvote
D Dragoic Honorable May 5, 2013 164 0 10,710 Mar 11, 2014 #18 Able to zip the .minecraft and send a download link to me. I do not need your saved games. Upvote 0 Downvote
V Vojin Honorable Dec 26, 2013 292 0 10,860 Mar 12, 2014 #19 thnx,but i found way,it wors on integrated gpu Upvote 0 Downvote
