HELP - Motherboard Beep Code and BIOS loading on start-up!
Oct 18, 2018
My PC boots straight to BIOS on startup, and when I press the power button on the IO it makes a single beep code; but I don't know what it means. I literally just got the PC today from PCSpecialist. When I got it I mounted in my own Kingston 240GB SSD and hooked it up to the Mobo. As I wanted my OS on my SSD and they had already installed it on my HDD, I used cloning software to achieve this. However, the first time I booted up my computer the single beep code sounded, and it does it every time now. Also, every time I restart my computer/turn it off and on again it loads the options menu before BIOS (I don't know what it's called) where it says which keys take you to which part of the BIOS before I can log on. I literally just got the PC and I want to use it confidently ASAP. Any help is appreciated!!!
My basic specs are:
Intel i5-8600k @ 3.6GHz
Gainward GeForce GTX 1070ti
Gigabyte z370p D3 (Mobo)
8GB (2x4GB) Corsair Vengeance RAM
1TB Seagate Barracuda HDD
240GB Kingston SSD
Ralston18
Motherboards generate beeps as a way to indicate problems at start up.
Go to your motherboard's manufacturer's website and look for the beep codes that they use for error codes.
The information may also be in the User Guide/Manual for your motherboard. Most likely in some troubleshooting section.
Or just google: "motherboard Gigabyte z370p error code beeps" . Hopefully some applicable beep code table will be found.
If not, vary the search criteria and try again.
