HELP!!!! Motherboard heats upto 62-65 degree
Praviin Samuel
238
After i play a game and quit
these temps i get and cabinet heats up
M5A99X pro r 2.0 Motherboard - 62-65 degree
FX 8350 not overclocked Cpu - 60 degree
Asus r9 390x Strix 8GB OC GPU - 80 degree
Hardisk 500gb and 1TB - 55 degree and above
Cooler Master Seidon 120M Cooling
Using Corsair CX 750w
G-skill 1866Mhz RAM
everything is producing heat than normal any suggestions?
is it because of poor power? or anything?
If your temperatures were fine before and tis rise in temperature is recent, then the issue is likely caused by one of these:
1. Your fans, heatsink, components or vents are covered in dust.
2. One of your fans is not working properly.
As I suggested earlier, it is a good idea to give everything a good dust. I usually use compressed air or a device that releases air like a pump for the hard to reach or delicate parts of my PC. On the parts that don't contain electronics, I usually use a vaccuum or damp cloth to remove the dust.
While all the temperatures are on the high side, they are not yet critical.
Not sure if this applies to you but you could try cleaning all your fans, vents, components and heatsink so they are free from dust and work efficiently.
okay thanks!
okay will raiding my 390x speed help ?
and pointing directkly near my cpu socket? how?
my side panel is glass no fans can be installed
