Hello, I've run into a big problem. I'm only semi tech savvy so I thought I would ask here. I didn't realize iTunes stored my music and movie library locally on my computer. As a result, my C: drive is 95% full. My iTunes folder is located in This PC > Music. When I click on iTunes in my Music folder there's a file called iTunes Library which contains a ton of movies which i suspect is taking up all my C: space.
I have a second mechanical HD (E
on the same computer which is totally empty. Is it possible to move all my iTunes stuff from the C: to the E: to free up space on drive C:? If so, is it easy enough for a non-tech savvy person like me to pull this off? I'm just afraid that I'll mess it up and it wont work.
[OS = Windows 10]
Thank you
[OS = Windows 10]
Thank you
