Hello all new to forum 3 days now been trying to OC
after playing at 1.2ghz for a year underclocked somehow, im not too fast but i figured something was wrong 😀 i concluded that i need help so TomsHardware next stop
i bought this (lots of text incoming)
if you are still here then Thank you
i know its alot to go through
what happens is after i OC through BIOS
i get 4.4ghz in CPUZ as im ment to
but then i try reboot and it reverts back to 3.6ghz stock now its only the speed
"non of the settings reverts" and is also saved as OC profile so i can quick open
its all the same just core speed drops to stock, i flashed bios to latest 0.80v also ran with allmost everything off since i have a feeling u might mention EIST and did prime95 and occt after reboot to see if the 3.6ghz would boot up till the designated 4.4ghz but no
the core multiplier 100* i can not touch even 101 does bad OC and reset dont get me wrong 100*44 is also fine if it would work where i auto the ram at 1600mhz frequency, this you see on images was a vague attempt (1866 unlink) is because i cant get it to work so might as well get most out of ram with stock speed atleast thats what i was thinking....
i do have mygenie clickbios II it does the exact same after reboot but tbh i rather do it myself also for learnings sake not that im a complete noob somethings do stick thank god 😀 but this process probably gave me 1-2 more grey hairs
TLDR*
BIOS updated
every setting remains intact
OC speed reverts back to stock speed on reboot
all eco eist turboenhancers turning on/off does not help
the reason im here is that i have a Gut feeling that i am missing one little dumb cvar or setting somewhere or im OC too much i also tried lower the clock 42* 40* etc i get the speed but after reboot it resets to stock
thank you for reading looking forward to some help
really needed....
regards
Code:
Summary
Operating System
Windows 7 Home Premium 64-bit SP1
CPU
Intel Core i7 3820 @ 3.60GHz 45 °C
Sandy Bridge-E 32nm Technology
RAM
16,0GB DDR3 @ 933MHz (11-12-12-32)
Motherboard
MSI X79A-GD45 Plus (MS-7760) (SOCKET 0) 31 °C
Graphics
S27B550 (1920x1080@60Hz)
2047MB NVIDIA GeForce GTX 660 (MSI) 30 °C
ForceWare version: 335.23
SLI Disabled
Storage
931GB ATA WDC WD10EARX-00N SCSI Disk Device (SATA) 26 °C
111GB ATA INTEL SSDSC2CW12 SCSI Disk Device (SSD)
465GB Western Digital WD Elements 10A2 USB Device (USB (SATA)) 34 °C
Optical Drives
TSSTcorp CDDVDW SH-224BB SCSI CdRom Device
Audio
NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
Operating System
Computer type: Desktop
Installation Date: 17-04-2014 21:22:58
Serial Number: D8X7P-3TKCQ-8682J-JB7T9-YKR3X
Windows Security Center
User Account Control (UAC) Enabled
Notify level 1 - Rare Notify
Firewall Enabled
RAM
Memory slots
Total memory slots 8
Used memory slots 4
Free memory slots 4
Memory
Type DDR3
Size 16384 MBytes
DRAM Frequency 933,4 MHz
CAS# Latency (CL) 11 clocks
RAS# to CAS# Delay (tRCD) 12 clocks
RAS# Precharge (tRP) 12 clocks
Cycle Time (tRAS) 32 clocks
Command Rate (CR) 1T
Physical Memory
Memory Usage 14 %
Total Physical 16 GB
Available Physical 14 GB
Total Virtual 32 GB
Available Virtual 29 GB
Motherboard
Manufacturer MSI
Model X79A-GD45 Plus (MS-7760) (SOCKET 0)
Version 3.0
Chipset Vendor Intel
Chipset Model Sandy Bridge-E
Chipset Revision 07
Southbridge Vendor Intel
Southbridge Model X79
Southbridge Revision 06
System Temperature 31 °C
BIOS
Brand American Megatrends Inc.
Version V17.8
Date 11-02-2014
Voltage
+3.3V 3,360 V
CPU CORE 1,352 V
VIN2 1,648 V
VIN3 1,411 V
+5V 5,634 V
+12V 8,976 V
VIN6 1,744 V
VSB3V 3,344 V
CMOS BATTERY 3,312 V
Graphics
Monitor
Name S27B550 on NVIDIA GeForce GTX 660
Current Resolution 1920x1080 pixels
Work Resolution 1920x1040 pixels
State Enabled, Primary, Output devices support
Monitor Width 1920
Monitor Height 1080
Monitor BPP 32 bits per pixel
Monitor Frequency 60 Hz
Device \\.\DISPLAY1\Monitor0
Manufacturer NVIDIA
Model GeForce GTX 660
Device ID 10DE-11C0
Revision A2
Subvendor MSI (1462)
Current Performance Level Level 1
Current GPU Clock 324 MHz
Current Memory Clock 324 MHz
Voltage 0,862 V
Current Performance Level Level 0
Voltage 0,862 V
Bus Interface PCI Express x16
Temperature 30 °C
SLI Disabled
Driver version 9.18.13.3523
BIOS Version 80.06.28.00.39
Physical Memory 2047 MB
Virtual Memory 2048 MB
Count of performance levels : 4
Level 1 - "2D Desktop"
GPU Clock 324 MHz
Level 2 - "Default"
GPU Clock 324 MHz
Memory Clock 810 MHz
Level 3 - "3D Applications"
GPU Clock 549 MHz
Memory Clock 3004 MHz
Level 4 - "3D Applications"
GPU Clock 549 MHz
Count of performance levels : 1
Level 1
Manufacturer NVIDIA
Device ID 10DE-11C0
Revision A2
Voltage 0,862 V
Voltage 0,862 V
Temperature 30 °C
SLI Disabled
GPU Clock 324 MHz
Level 2 - "Default"
GPU Clock 324 MHz
GPU Clock 549 MHz
GPU Clock 549 MHz
Level 1
Storage
Hard drives
Heads 16
Cylinders 121.601
Tracks 31.008.255
Sectors 1.953.520.065
SATA type SATA-III 6.0Gb/s
Device type Fixed
ATA Standard ATA8-ACS
Serial Number WD-WCC0S0536811
LBA Size 48-bit LBA
Power On Count 586 times
Power On Time 239,7 days
Features S.M.A.R.T., NCQ
Max. Transfer Mode SATA III 6.0Gb/s
Used Transfer Mode SATA III 6.0Gb/s
Interface SATA
Capacity 931 GB
Real size 1.000.204.886.016 bytes
RAID Type None
Heads 16
Cylinders 14.593
Tracks 3.721.215
Sectors 234.436.545
Device type Fixed
ATA Standard ACS2
Serial Number CVCV307302X9120BGN
LBA Size 48-bit LBA
Power On Count 576 times
Power On Time 37512,1 days
Speed Not used (SSD Drive)
Features S.M.A.R.T., APM, NCQ, TRIM, SSD
Interface SATA
Capacity 111 GB
Real size 120.034.123.776 bytes
RAID Type None
Manufacturer Western Digital
Heads 16
Cylinders 60.797
Tracks 15.503.235
Sectors 976.703.805
SATA type SATA-II 3.0Gb/s
Device type Fixed
Serial Number WD-WX91E13XJL56
LBA Size 48-bit LBA
Power On Count 477 times
Power On Time 178,3 days
Speed 5400 RPM
Max. Transfer Mode SATA II 3.0Gb/s
Used Transfer Mode SATA II 3.0Gb/s
Interface USB (SATA)
Capacity 465 GB
Real size 500.074.283.008 bytes
RAID Type None
Watercooled intel i dont know exact brand
i know its alot to go throughwhat happens is after i OC through BIOS
TLDR*
BIOS updated
really needed....
regards
