Help my ASUS m5a99fx pro memok dram blinks red! First boot!
S0nar
6
Hey fellow computer scientists,
Just purchased a brand new system and can't get it to work. The motherboard light is green so I know their is power and the cpu fan turns on but I keep getting blinking red lights 🙁
-ASUS m5a99fx pro motherboard
-AMD fx 8350 4GHZ 16MB 125W AM3+CPU 8-core Processor black edition
-Corsair Vengeance blue 16GB 1600mhz RAM
-Thermaltake TR-700 700wt RT
Is my set up incompatible? Why are the lights blinking red while the motherboard light is green?
Best Regards,
S0nar
Try reseating your RAM. Also are you using all the DIMM slots or just two. If you aren't occupying all the slots, make sure you have the RAM in the slots designated for just two DIMMs.
If that doesn't help, does your motheboard have a Mem OK button? If it does, try pushing that and try booting.
Also you could try resetting the CMOS.
Thank you for the quick response techgeek! I reseated the ram three times just to make sure and still the light blinks red. Yes I press the MemOK button and it blinks red. Fyi this a first boot with everything being brand new just un-boxed today and I'm using a 1024mb gigabyte xlr8 performance edition just to test my computer before my r9 290 arrives in the mail.
I forgot to plug in the epu 12v and now the lights stopped blinking 😀 and I got to the bios screen but now I get a cpu fan error but I have it plugged in? Also I tried to boot it off a HDD and it will show the windows logo upon boot but the motherboard will just turn off and restart?
p.s. If it will make it easier I can post pictures?
Thank you
Update* Just noticed a solid red light boot_device_led
Is the fan turning? In the monitoring tab, does the fan show a RPM?
As for the booting off the HDD, was there an old install from another computer on it? If so, you'll have to do a full fresh install because the drivers that are being loaded for the old system will likely cause a BSOD or restart.
Was this ever resolved? I've been up and down the related threads about this mobo/issue and there doesn't seem to be any particular resolutions. This is my 15th or so build, i've checked off all the 'noob' mistakes (power connectors, seating issues, etc) and i'm still getting the ASUS MemOK Red light of death. Anyone have any 'hail mary' ideas possibly not tested yet? I'm running the M5a99fx Pro R.2, FX-6300, Xfire XFX HD7870s, Corsair RM750, my custom water-cooling, GSKILL Sniper 16gb(8x2)..but all that is quite useless if the board won't get past it's own self tests 😛
Thanks!
It was solved by formatting & using a fresh install of Windows. My mistake was that I pulled a hdd from a older computer with Windows already installed.
