Existz Prominent Jul 7, 2019 17 0 510 Sep 12, 2019 #1 The taskbar icon became white paper but the icon on the desktop was normal. what should i do? thanks
Solution britechguy Sep 12, 2019 Try rebuilding your icon cache. I have no idea which tutorial you'll find preferable, but there are scads returned by this search: https://duckduckgo.com/?q=windows+10+reset+icon+cache
kerberos_20 Champion Dec 24, 2011 9,923 1,593 55,740 Sep 12, 2019 #2 unpin it, than pin it again Upvote 0 Downvote
Existz Prominent Jul 7, 2019 17 0 510 Sep 12, 2019 #3 kerberos_20 said: unpin it, than pin it again Click to expand... i did, not working. still white paper icon after i re-add. Upvote 0 Downvote
britechguy Commendable Jul 2, 2019 1,479 240 1,340 Sep 12, 2019 Solution #4 Try rebuilding your icon cache. I have no idea which tutorial you'll find preferable, but there are scads returned by this search: https://duckduckgo.com/?q=windows+10+reset+icon+cache Upvote 0 Downvote Solution
