Archived from groups: microsoft.public.windowsxp.hardware (
More info?)
Also check the circuit breakers and/or fuses for that power line.
"LVTravel" <none@nothere.com> wrote in message
news:112e7ke9ld86re8@corp.supernews.com...
> Of course, first check the obvious. Is it plugged into a working outlet
> (plug a lamp into the outlet and make sure it is turned on?) Is the power
> cable plugged into the back of the computer (they can work loose when
> moving a computer on a desk or floor?) If there is a rocker switch on the
> back of the computer is the switch turned on (I/O with I pushed in?) If
> you are hooked to a surge suppressor or switchbox (had a switch go bad
> once), remove them and try into an outlet directly.
> "Richard Urban" <richardurbanREMOVETHIS@hotmail.com> wrote in message
> news:utPfOS%23HFHA.1860@TK2MSFTNGP15.phx.gbl...
>> If you don't have the necessary electrical test equipment (and the
>> requisite knowledge to use them), or a stock of spare replacement parts -
>> take it to a service shop!
>> I would imagine that you don't as per the nature of your post! Testing,
>> or part substitution, is the only way to diagnose the problem.
>> Regards,
>> Richard Urban
>> aka Crusty (-: Old B@stard
>> If you knew as much as you think you know,
>> You would realize that you don't know what you thought you knew!
>> "Finemom02" <Finemom02.1laz1n@pcbanter.net> wrote in message
>> news:Finemom02.1laz1n@pcbanter.net...
>>> When I turn on my computer , ther is no lights , there is nothing.
>>> Please help.
>>> Finemom02
