Help my computer is not working how it should
Wraymann
Commendable
Jan 2, 2017
8
Specs :
GPU: msi gtx 1080 gaming x
CPU: Intel core i5 6600k
RAM:Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2133 Memory
Motherboard:MSI B150 Gaming M3 ATX LGA1151 Motherboard
PSU:EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply
I built this computer so that I could play games like CSGO, BF1 , and Overwatch but I am only getting 130 to 200 FPS in CSGO and the same with overwatch , Battlefield one place at about 60 FPS with all low settings and I know it should be more is there anything that might be happening in my computer or anything that might've happened to one of the parts to make it to this but I need to know about?
and this is a problem?
Anything over 100 FPS is plenty for CS:GO without a very VERY high refresh rate monitor same goes for overwatch so this is a non-issue.
Secondly BF1 likely just has VSync turned on.
Final answer: You have a very very good computer that is performing exactly as would be expected with the hardware and well above what is required for even fantastic gameplay so there are no issues.
Lordprometheus I think you're wrong on this one I have had many people tell me I should be getting around 600 FPS In csgo , and I did unlimit it because I know that it is limited to 300 in game; also my computer should be able to handle these way better than this but it's not I know people with 8 GB of RAM 980 TI's and 6500 K processors they can run it at 300 FPS easily so I'm fairly sure there's something wrong
