Can someone please help me?
I have a 520volt OCZ PowerStream PSU and a Asus A8N-SLI Deluxe motherboard. When I try to turn on the system (yes, the cables are all plugged in), I get a 1/4 second of power and then it quits.
When I turn on the back switch, the Asus green light shows up on the motherboard which is a good sign (I think). But the system does not boot up.
For information
I use a AMD 64 FX-53 with a Asus Star ICe CPU color.
Things I tried;
1. took out my 6800GT video card and try to keep everything basic to boot up.
2. Do you think my CPU is bad?
Note: I think I can rule out that the Asus A8N-SLI Deluxe card is find since I see the green light show up.
3. Do you think it is my Dual 512 x 2 DDR2 memory? Well, usually you can start up the powersupply and if memory is a problem there should be a beeping sound....but I have not even got that far yet. So my guess I can rule out memory.
4. The voltage requirement for Japan is 115V (like the states). Note, I got my OCZ power supply from a vender online from the states. This should be fine.
5. Also, my OCZ PS supports 24-pin EATXPWR1 and 4-pin ATX12v1 which are both properly connected. This should not be the problem.
Hmmmmmm. It seems maybe my power cord is the problem .....its like there is not enough power...maybe I need more power from my outlet?
Any suggestions where to go from here?
HW Specs
Asus A8N-SLI DX
AMD-64 FX-53
1 Gig DR400(Dual)
Asus Star Ice (CPU Cooler)
OCZ PowerStream 520PSU
2 Nvidia 6800GT SLI
Lian Li PC-V2000B MOD w blowhole
For information
Things I tried;
HW Specs
Asus A8N-SLI DX
AMD-64 FX-53
1 Gig DR400(Dual)
2 Nvidia 6800GT SLI
