Question Help!! My computer won’t connect to internet no matter what!!
TheLoveDoctor
Commendable
Jun 15, 2017
Hello, I’m having a problem that’s really worrying me and I’m in desperate need for help. My computer was working fine a few days ago, but two days ago I turned off my pc, and when I came back to turn it on, it had no internet. I’ve tried every solution I could think of to resolve this issue: I tried using an ethernet, but it didn’t work, the lights of the ethernet port don’t even turn on. I tried unplugging and plugging my router on and off, and nothing. I tried to restart my network settings just incase, but that didn’t work either. Everytime I try to connect to my wifi, it says “can’t connect to this internet”. This is mainly acting up on my pc, everything else is fine. Please help!!!
hang-the-9
If you don't have link lights it means you don't have a connection to the router with cable not working or router port is bad or your network card is dead. You should have a system restore point available, restore the system to a time before this issue started and see if that fixes things.
