I have an external Seagate HDD and only recently it has started appearing in Explorer as a DVD-ROM (with a H: Drive letter association.) I'm running Windows 8.1
Checking Device Manager shows the device as a Disk Drive, which is correct. I've tried disabling/uninstalling/reinstalling - keeps mounting as a DVD-ROM.
Checking Computer Management I do see the device listed as a DVD-ROM. Changing the drive letter does not help (changed from P to H earlier) and nothing can be changed from the Properties. Yes, I've tried uninstalling and reinstalling the driver from here as well.
I've also connected the HDD to USB2 and USB3 ports on the back and front of the PC. Made no difference.
If I try to access the drive through CMD by typing in: cd H:/ it tells me 'the device is not ready'. Through PowerShell it tells me the H: drive does not exist.
If I recall correctly I may have put an ISO on the root folder of the drive, which I believe is causing the issue as it was an OS recovery image that may be trying to mount as a disk, but I can't access the drive to delete/move the file. I've read countless threads on the issue and no one has solved it. Formatting the device is not an option as it has a TB of personal data that can't be lost. This is my backup drive.
Can anyone one here help me return this to a HDD mount?
