Help! My gaming pc? and my vram too low??
All you do is restart your computer and before the Operating System starts to boot, you will see a screen for like two seconds that has something like "F12 = BIOS" or something similar and it will give you the brand name of your motherboard.
bmanv13
304
You some how are using your integrated graphics instead of using your GPU. You need to go into the bios and disable your integrated graphics and enable your dedicated one (if option is available or the dedicated one).
TheFalseShepherd
36
Sorry for being so dumb at computers, but how do i go into bios?
bmanv13
304
TheFalseShepherd
36
Thank You!
