Question HELP !!! MY gpu RX 580 MSI GAMING X 4GB with furmark please help :(
Jun 19, 2019
14
i run furmark to test my gpu but when it at 40% ,, screen turns off and gpu fan's running at high speed that i powered off case and then run it again ?? what is this and what should i doooo ????????????
my specs :
MB : B450 AORUS ELITE
CPU : AMD RYZEN 5 -2600
RAM : 16GB 3000GHZ
PSU : COOLER MASTER 600 WATT
Provide full and complete PC specs. What's the make/model number of your POWER SUPPLY unit/PSU ? Don't use furmark to stress test the GPU. How does the RX 580 perform in GAMES ??
You didn't answer my question ::: How does the RX 580 perform in GAMES ?? List the exact MODEL number of that CM 600 Watts PSU.
Case Cooler master CMP 500 - has 600 watt power ,, in games it is very good
So the PSU came with the cabinet itself ?? Anyways, I wouldn't worry much since there are no issues playing games. Do not use Furmark. Try running some other synthetic GPU benchmarks, if need be.
