Help My GPU Usage high w/out doing any thing
Stay Connect
171
MY GPU CLOCK and MEMORY CLOCK is sometimes high, sometimes low
what happen? see image below
this is normal help and explain please
If you aren't experiencing any in-game fps drops, then this is just the way graphics cards work. They turn themselves down if they are not being used.
If this is messing up gameplay, then you may have a problem. But it looks like this is the card at idle(since the temps are in the 40C's the whole time).
This isnt bad for your card, don't worry about it 😀
pretty sure?
any way thanks
any explanatin...
You are not showing a graph of usage. You are showing a graph of clocks and voltage. My guess is you are using applications with hardware acceleration, which will cause your GPU to increase its clock rates while being used to help accelerate what ever the software is doing. Logitech gaming software does this, most browsers do this, flash does it, and a number of other applications use hardware acceleration. The GPU "usage" is still likely low, but the clocks will increase while using these applications. Most these applications do have settings that allow you to turn off hardware acceleration, but are usually set to be on by default.
thanks for explanation sir.
Latest posts
