help my h100i is not cooling my i5 7600k
Liam_62
help my h100i is not cooling my cpu my h100i runing with 100% fan speed with 1.2v to the core is geting 90c when other peaple with h100 v2 on same cpu (i5 7600k) runing on 1.375 v under 90c also the radiator is not warm to the touch even when cpu at 90c i know this is the right temp because biose says the same temp and real temp and every other temp monitoring program it is not the thermal past because i have reaplied meny times at different volumes i watched an inslallashon video and he used the same typr of screw to screw in the mother bored do i need the h100 v2 for the new i5 ? insted of the h100i ??? please help
This is why I rarely suggest and only twice have used in a build for a customer a water-cooled setup. A good air cooler is REAL close in performance to even $120 water coolers. And as long as you install an air-cooler properly all you have to do is see if the fan is working and you're good. Pumps/waterborne/airbubbles cause so many headaches in aio
