Help my Hard Drive has disappeared!!!
PolanaMaster
71
Hello everyone I recently have bought a new pc and everything was ok until my Hard Drive has disappeared suddenly. Do you know what could the reason be? Is it something to do with faulty hard drive,sata cable or motherboard?
Thanks for answering :) :) :)
Follow these steps:
1. Open PC chassis to see if the HDD is physically still present in your system.
2. Check that the HDD has a connected power cable and data cable.. The power cable must be connected to the HDD and the PSU. The data cable must run from the motherboard SATA header to the HDD. Check these connections.
3. Boot PC and press either F2, F10 or del to go into bios. Under storage or HDD settings tab, see if all your HDD's and optical drives are listed. If they are indeed listed don't change anything. Exit BIOS without saving.
4. PC will reboot once you exit BIOS. Wait for OS to boot. Once in OS (assuming windows), press windows button and "r" to bring up the run box. Type "compmgmt.msc" without the inverted commas. Wait a few...
Follow these steps:
4. PC will reboot once you exit BIOS. Wait for OS to boot. Once in OS (assuming windows), press windows button and "r" to bring up the run box. Type "compmgmt.msc" without the inverted commas. Wait a few seconds and a new window will open. On the left of that window navigate to storage -> disk management.
5. Let me know what you see here. A screenshot would be nice...
