I have Lenovo IdeaPad Gaming 3 82K100Y3PH and MSI optix g241 but only having 120hz display. Asking help if what I can do to maximize it to 144hz. Already tried changing display options refresh rate
From what I can recall you need a bandwidth of 12+gb/s for 1440p 144hz. Pending your gpu (and monitor, but if they advertise 1440p 144hz that end should be good) you need hdmi 2.0 or DP 1.2 or higher to achieve that res/ref rate.
Look up your gpu specs to see what your gpu output is to see if your ports on the gou support those outputs. DQFanSurvey
