Hey everyone! I know that overclocking is either hit or miss, and I think I was just unlucky with my processor, but any suggestions are greatly appreciated. My setup is: P4 2.8C, 512mb dual channel Geil PC4000 @ 1:1, Abit IC7, Thermalright SP-94 w/92mm Tornado, 2 WD Raptors in Raid 0, FX5950 ultra, 500 watt Allied psu, all installed in Antec tower case, with mega air cooling:2x80mm front,2x80mm rear,2x80mm side, 1x120mm side, and 1x120mm top. Front and side fans blow in, while back and top blow out.
At stock voltage, I can get up to 230fsb @1:1 However, after that, it really takes a lot of voltage to get it to go any higher. I can post at 250fsb 1:1, but not completely stable. This is with 1.7 volts. The highest I can get stable with 1.7 volts is 245 fsb. At this speed temps are 39 Idle, 49 Load. The processor is not running hot at all. I dont think temps are the problem. When I had it at 250fsb, i was able to complete a couple runs of 3DMark and temps did not go over 50 C. What is holding me back? How safe can I go with my VCore??? If my temps are still below like 55 C, can i jack the VCore up to 1.75??? Any help is greatly appreciated. P.S. I disabled dual channel memory and it still does not work stably at 250FSb 1:1. I also tried using 5:4 and 3:2 divider on ram, and still no luck. I can start Windows at 255 fsb, but not stable, so I dont think it is my Mobo, Please help.
