Help! My Mini-PC is hitting 60c Idle
TronPrime1
Hi,
I have a Dell inspiron zino HD that's CPU is currently running 60 degrees (Celsius) at idle! I've looked around and there seems to be no solution on the internet... I have cracked open the case before and vacuumed it out but it still is heating up to 60 degrees. 🙁
Any help would be appreciated
Thanks!
Cute pc.
Has it run cooler before?
If so, I might suspect that the cpu cooler has come loose or the grease has deteriorated.
If it has always run hot, then you might change out the cooling fan for a higher cfm version.
The drawback will be added noise.
