New one or old one stopped showing ?i have checked my bios and checked in windows, its just not showing up. are there any setting i should change?
motherboard : gigabyte b450 aorus elite
SSD: Kingston a400 240gb ssd
can anyone help?
2.5" or M.2?i have checked my bios and checked in windows, its just not showing up. are there any setting i should change?
can anyone help?
If it is M.2 Kingston a400 model, then you can put it only in M2_A sloti have checked my bios and checked in windows, its just not showing up. are there any setting i should change?
can anyone help?
(closest to cpu, under heat shield).
Second M.2 slot (M2_B) doesn't support sata M.2 drives.
i tried it in the top one too it still wouldn't show upIf it is M.2 Kingston a400 model, then you can put it only in M2_A slot
Any other drives already connected before you installed it the top slot disables a SATA port.i tried it in the top one too it still wouldn't show up
Is your drive in M.2 or 2.5" form factor?its in the top port
M.2
2.5"
m.2Is your drive in M.2 or 2.5" form factor?
M.2
2.5"
