Help my old samsung laptop won’t turn on, i’ve tried searching for the solution on internet but none worked
alifhaikal243
My laptop is a samsung laptop, I can’t remember the model as I lost the packaging box when I moved into my new house, when i plugged in the charger, there is only one light indicator are on which looks i don’t know what it stands for, and sometimes the light indicator for the power turns on just for a second and it turns off again
Yeah, some laptops won't work if the battery is removed, charger connected or not. It could be a few things. With the problem you are having it is mostly a process of elimination.
NOTE: Yes, I know some batteries are not so easy to get to, on some devices. However, it should be removable/replaceable. Unless it is under warranty, then you should contact the manufacturer first.
Try the following and see if it will turn on...
1. Unplug your charger cord.
2. Remove the battery.
3. Press and hold the "Power" button for 30 seconds.
4. Now plug back in the power/charger cord.
5. Now put the battery back in.
If this doesn't help, then test the power cord to see if it is good. Either try your cord in another device, or try another devices cord in your laptop. You may also want to try charging it when the device is off, rather than on. If it works then, the cord is probably the issue.
Should that not be the problem, then check the battery to see if it needs replacing.
Well uhm yeah I’ve tried that step because most answers I found online are the same and it didn’t worked, I tried removing the battery and plugging in the charger and the same thing happens where there is one light which constantly blinks and the power light blinks for a second in a few seconds
