Help I put all my info in this video so please help in ur comments or here I need my pic soon so help.
View: https://youtu.be/kOn268hyWGY
The amber light is a trouble lite that lites to show where it failed in POST (power on self test). It could be VGA, CPU, Memory or Boot, meaning the boot partition on the system drive. Which one is it? you'll have to look close to see the tiny writing next to them.Anyone?
monitor is connected to my rtx 2080 super via hdmy and i just plugged in my drivesThe amber light is a trouble lite that lites to show where it failed in POST (power on self test). It could be VGA, CPU, Memory or Boot, meaning the boot partition on the system drive. Which one is it? you'll have to look close to see the tiny writing next to them.
A likely suspect is the VGA...your monitor should be connected to your discrete GPU, not a connector on the motherboard. Otherwise, check all connections. Especially those to system drives.
